Lutz Kramer
I have an AH 3000 BJ8 with two SU HD8 carburetors. I found 4 gaskets for each carburetor in the following sequence:
air filter -> gasket #1 -> carburator -> gasket #2 -> heat shield -> gasket #3 -> insulating block -> gasket #4 -> inlet manifold
Gaskets #1 to #3 are paper gaskets, while #4 seems to be made of a kind of a metal, which has a lot of factory made press-fit recesses (the best I can describe it).
Question is, whether this kind of seal ist original, because I couldn’t find it in any oft he parts catalogues and whether it seals air tight without using a sealant like for instance Hylomar?
