I have a 54 BN1 with H4 carbs, I have my engine up and running after a rebuild, I did raise compression and go to a M spec cam, I would have guessed if anything I would need to enrichen the mixture with the new specs.
I have the mixture nuts all the way to the top and it is still too rich--when I raise the pistons slightly or even more than slightly it speeds up.
I have checked the choke adjustment and jets they are not stuck open.
I have two theories, carbs are just way worn out (I have not replaced the jets and needles) or my aftermarket fuel pump is pumping too much gas, it seems to be defeating the needles. The pump is supposed to be the low pressure facet, 1.5-4.5 pounds) but it seems to be pumping too much juice. I had grose jets, but put my needles back in, no discernable difference.
I am in the process of getting the old SU pump fixed/replaced--any other thoughts on this issue.
Hi Guest!
