I have determined that the carbs that I bought were from a '72. The tag # is 3777 L/R. I have them cleaned, rebuilt and installed on on the car. The car started fine and seems to run ok. It is still running lean. I lifted the pistons on each carb just a little and the rpm's dropped and the car stalled. I turned the mixture adjustment to the stops both ways and it did not make any difference. Do you think that lowering the floats a little would help? Is there any adjustment on jet height?
Thanks again, Pete
Thanks again, Pete
