I have had a "wet" carb issue for some time now and the wife has banished the TR6 (73)to the backyard shed from the attached garage. Apparently some people don't like the smell of raw gas?
Took another stab at it yesterday; removed, cleaned, set floats, tested vent chamber valve,removed and cleaned choke,checked needle adjustment apparatus. Put everything back together, adjusted air and mixture. Thought I had it; no leaks in driveway, no misfires etc. Went for short drive and all of a sudden its a dog! Ok under acceleration, but not cruising or idling. Got home, popped the hood, and saw that body metal crease just under the carbs full of gas-pooling. Even after stopped for awhile it continued to drip. The I noticed it was dripping from the vent chamber hose which goes to the carbon canister. I detached the hose at the carb, lowered and turned upside down and gas poured out! BTW, the air filter on that carb was also soaked. When cleaning etc., I checked that at idle the valve from float chamber to air filter vent hole was plugged as it should be (sucking and blowing on hose fitted into vent hole).
My guess is gas was being sucked into canister hose at idle and into air filter vent off idle. Doesn't this only mean that the float and/or float valve are not working and the float chamber is full? Tested perfectly off the car?
Sorry for being so long winded, and appreciate any ideas you may have. Got to get this car back on the playing bench (attached garage) and out of the locker room (shed).
