TR6 carbon canister
I don't know which year your carbs are but if they are 73-76 they would have nipples on the left side like the one in this picture that I colored red. They should not be capped off if you remove the CC. They are vents for the carbs' float chamber and must remain open to the atmosphere.
On the right side of the carbs pointing up at a slight angle are similar size nipples that originally not only were connected to the CC, but also the valve cover.
You can eliminate the connection to the CC but at least one of the carbs needs to remain connected to the Valve Cover in order to relieve crankcase pressure... Also ...NOTE the Banjo fitting on the intake manifold.
Like so:
OR like so:
Basically any nipple EXCEPT the "red" ones need to be capped off if not in use.
Thanks, by eliminatiing the canister will hopefully solve my idling issues I can't seem to get a nice steady 850-950 rpm
I'd try it unhooked before deep sixing them
I can't imagine the CC per se causing any such problem...
BTW what year are your carbs? ..you never did reveal it.. even as much as I've hinted at that fact.
Ken- Sometimes ya got to hit em with a brick :angel2:
FWIW, I've had good luck with capping both vacuum taps, and just running an open hose from the rocker cover fitting down to somewhere near the ground. This was an engine that was kind of "tired" and would generate more blowby than the carbs could handle, resulting in various oil leaks. Leaving the vent open like that stopped the oil coming out past the rocker cover gasket, and cut way down on the oil coming out the front & rear main seals.
Would that have been a TR6 engine with the non-vented oil filler cap, Randall ?
A timely post for my purposes as the start up of the new engine has been delayed once again due to work issues. Retired in June and been busier with my so-called part-time retirement gig than my old full-time job. Anyway, I have a replacement '75 engine in my '76 with no EGR (removed and plugged), no air pump, etc, which leaves me with the carbon canister and the anti run-on valve (which has a busted electrical connection anyway) so I'd like to leave the canister and valve off the new setup. Is this going to be a problem? I plan on following Ken's (poolboy's) advice on the nipple issues :wink-new: and simply leave off the canister and anti run-on valve. Apparently, one of the wires on the anti run-on valve was busted before I ever took the car apart and I experienced no issues so it seems like a non-issue to me at this point. If the carbon canister is deleted, what happens to the hose(s) coming from the rear of the car? Cap off?
Thanks,
NO..NO..don't cap that hose, Bob.
It's the vent for the gas tank and if plugged a vacuum will build in the gas tank as the fuel level drops..then the gas stops gravity flowing into the fuel pump and then the carbs run dry and the engine stops.
If you remove the CC there are a coupls of options..
On my 74, I ran that hose to the front carb, to the nipple that would have ordinarily been conjoined with the rear carb to the valve cover. Rear carb to the valve cover..front carb to the gas tank vent.
On my 73, the hose was simply cut and left dangling straight down slightly above the nearest part of the frame...
I thought I was smelling the odor of gas, so I extended the vent hose to a small motorcycle Carbon Canister bought off ebay that I strapped to the frame under the boot.
I continued to smell that gas, btw, and by removing the 'gas tank board' behind the seats, I discovered a loose hose clamp around the vent line and some dampness
Once tightened the odor left.
I know a couple of guys who just left the vent line unattached once the CC was removed.
Yes.
Since the cap is not vented, the crankcase eventually fills with blowby gases; but that is as original. Having the largish hose open to the atmosphere (ISTR we used 1/2" heater hose, but line rated for PCV use would be better) allows the excess gases to escape rather than build up pressure against the smaller ports (and restrictors) on the carbs.
Did you enlarge the diameter of the valve cover's nipple ?
Nope, just clamped the hose onto it. The heater line was soft enough that it would crush and grab the nipple.
Ok, just curious since I had the opposite experience. When I bought the 74 the PO attempted to make a 'road draft' tube from the valve cover vent with a long piece of red heater hose.
The engine was a grimy mess. I cleaned it up and connected the valve cover to the evacuation ports on the carbs with good results.
It was purely a stop-gap measure; the owner knew he needed new rings. But he was still driving it that way a couple of years later. We sorta lost touch after that though, so I don't know the end of the story.
73's..
Then you may trace the problem you are having back to this.
1973 was the year that the Anti Run-on Valve (ARV) was initiated and the arrangement that you see in this picture was conceived to accomodate it...however it must not have worked as well as hoped from the very beginning, because the next year in 1974, the arrangement was changed to a more sturdy, reliable arrangement which remained that way until the end of the TR6 run in 1976.
I've lost count of the number of people with 73 carbs that have had idle problems that were traced back to a malfunction of THAT vent valve. Rebuilding the carbs does not solve this particular problem..
Since there are no new replacement parts for this valve, I usually end up gutting the valve, which restores normal operatiion of the carbs and makes them function like the pre 73 carbs.
Another old saying: "Things left off a car can never give trouble".
Saw "Rush" last night. Great story, and true, too, but with a couple of Hollywood touches. See it.
