My 78 Midget shows signs of running rich...hesitation under a heavy foot, black fouled plugs, occassional backfire, and hints of black smoke at the tailpipe. Cleaning and replacing the plugs solves the symptoms temporarily, but after 15 miles or so, she's back where we started. The hesitation is no good in heavy traffic...gunna get swashed....or just stuck somehere having to call AAA.
I'm opening the water choke this week to see if she's opperating properly (runs like the choke's on all the time) but if that's not the culprit, I assume I need to look toward the carb. I can adjust the mixture with a special tool I have to order and, since I have to pay S/H anyway, was considering a carb rebuild kit and new needle "while the hood is up."
Assuming the H20 choke is OK, is the total carb rebuild going a bit too far to solve my problem, or should I just start by turning the adjustment screw and keep on driving? My goal is to just get solid throttle response, stop fouling my plugs, smoking, and smelling...and be able to get out of the way in rush hour traffic! Any wisdom you can share?
Hi Guest!
