TR6 Carb Spacer
G
GeneF
My 74 TR6 has been neglected for quite a while. I'm rebuilding the carbs in the hopes of getting it started ( one of the throttle plates is stuck shut from old gas )
I was wondering if I should replace the carb spacers while I'm at it. They look OK without taking them off.
Gene
If they are tight and not leaking should be OK. Ounce you get it started and fresh gas add Sea Foam to tank from any auto parts outfit. also get some carb cleaner spray can, spray it on the spacers while the car is running ( just a shot ) if RPM changes you have a vac leak
