Carb removal help
JPSmit
This is probably ridiculously obvious but it's making me crazy. I'm trying to get the carb off my 1500 ('76). When I losen the 1/2 nut on the top right my wrench gets stuck. To remove the wrench I have to re-tighten the nut. What am I missing?
I've tried to attach a picture of the nut in question.
thanks
JP
Good Morning ,
usually you will have to pull the carb away from the manifold as you loosen the nut. this should help with clearance. a small wire toothbrush and some penetrating oil will help clean things up and with any luck after you loosen the nut you might be able to use your fingers.
mark
got it finally. Why are things so hard the first time and so easy the next? (story O my life right there /ubbthreads/images/graemlins/smile.gif
For the return trip, or maybe next time, there is another solution. SnapOn makes a ratcheting open end; it has an unusual jaw opening, and one short leg which allows it to ratchet back. Perfect for this operation, but expensive.
Paul's right -- the right tool for the job is always important and can save hours, or even days, of frustration.
Many companies now offer the open-end ratcheting wrench -- even discount brands.
Ahhhh, I recall many days spent removing the right hand carb nut a sixth of a turn at a time. I never had special tools, I just used an open ended wrench. I seem to recall if you remove the plastic fitting for the crankcase ventilation system, you get a little more room to manuver the wrench around. Also, it helps if you tilt the wrench when you turn it.
I'm glad you got it loose.
