I need the mechanic's eye for the totally inept guy. I got the BT7 back from the garage and after replacing the fuel pump, it had a miss at low speeds....sort of like only firing on 5 cylinders....just had it tuned about 500 hundred miles ago.......anyway, it is not the easiest to get started in the cold, so I spray some starter fluid in the carbs and it usually does the trick. Not this time..no way, no how is this baby going to turn over. As I was mking the 10th trip under the hood to try and figure this out, I notice that one of the brass hexigon nuts at the top of the bell on the carbs was completely loose (you could see in the top)and the other was very loose. Could this be the source of my failure to start? I tightened them back up, by I need to charge the battery to see if it works. Any help would be appreciated.
