What gets connected to the bottom of the carb that is closest to the radiator? Located right near the spot where the carb is mounted to the manifold, there is a small port on the underside of the carb that tends to leak fuel. If I remember correctly when I purchased the car 2 years prior there was a rubber tube with a screw glued into it.
