My car starts fine with the choke on and idles well for a while with the choke off, well after the engine is up to temp. Then if I contiune to let it idle or drive it a little, the idle seems to slow and the car stalls. Then when I go to start it, it has a hard time to start. I recently had my HS6 Carbs rebushed and then I rebuilt them in my BJ7. I checked the timing with an advance light and I am running 15 degrees as in the book. Distributer seems to be fine. I initially tunes the carbs after the car was warmed up so I am not sure what I am missing. Could it be vapor lock? Any thoughts.
Thanks as always for the help.
Hi Guest!
