dklawson
Jack... can you really do that... run a dual carb car off a single carb by holding one butterfly completely closed? I'm almost afraid to try that. Could you walk me through your procedure? PM me if its too long and off topic for this thread. I'd appreciate it.
Dave, I agree that balancing the air flow at idle should keep them balanced through their range but it's never seemed to work well for me. From memory, don't the Haynes and SU manuals discuss disconnecting the linkage between the carbs and using the idle screws to move the butterflies until the air flow is balanced, then lock the linkage in place? My problem is that once I do that, the carbs are balanced at idle but off idle they don't track each other well. (No matter how careful I am tightening the linkage!) By balancing them at 2000 RPM they seem to stay together through the RPM range.
Carb adjustments are the thing I enjoy the least. I know with careful practice I'd get better at it... but I'd just assume not.
