Stick
As some of you may know, I'm finishing swapping a stock 1275 from a 73 midget into my bugeye racecar. As I'm now using the carbs and engine from the '73, there were more vacuum lines and emissions things (vs the race carbs that had none at all). So, I figured I would simply plug all of the vacuum hookups since I don't have anything to hook them to.
See below:
As you can see I have the vacuum hookups off the carbs run into the stock "Y" and then to open air
The intake manifold is also from the racecar, so where there seem to have been additional vacuum hookups on the manifold on the Midget, they are plugged on this manifold.
Here is another angle of the current setup.
So, the question is, why does it run better this way than when I have the 3rd leg of the "Y" plugged? I made a piece of hose with a bolt sealing the other end (good tight fit) to fit over the open end of the "Y" but when I put it on the car does not want to run as well. I tuned the car with the vacuum plugged, yet it never liked to run well that way.
When the vacuum is sealed the car will spit and kick when you give it gas, be hard or impossible to start when warm, and sometimes want to die at idle. Removing the plug seems to help tremendously with all of these problems, but I don't understand why. Seems to me the opposite should be true.
Any ideas?
Thanks,
Nathan
See below:
Any ideas?
Thanks,
Nathan
