I'm quickly succumbing to Analysis Paralysis.
What voltage should a 12 volt car battery read when it's "fully charged"?
Very close to 12 volts? or close to 13 volts? or 12.5? or ... ?
I'm trying to see if my battery maintainer is actually doing its job. If it goes from charging mode to maintainer mode when the battery voltage is 12.5 volts, is that "correct"?
On a related point, does a car battery charger have an internal standard that tells it to stop charging when the battery is at a certain voltage? (And if that's the case, then wouldn't different companies' chargers have different voltage cutoffs?)
Interesting and somewhat contradictory articles:
https://www.autobatteries.com/en-us/battery-testing-and-maintenance/car-battery-voltage-and-testing
https://www.batterystuff.com/kb/fre...ies-faq/12-volt-battery-reading-13-volts.html
Thanks.
Tom M.
Thanks.
Tom M.
Hi Guest!
