So I cut out a spare captive fitting from the TR7 parts car to try and fix this;
My question is if I "simply" need to open up the sheet metal here to gani access to the captive assembly retraining metal and weld in the replacement metal?
Re: Captive seat track mounting thread repair - id
Aloha Skip,
I think Phil's solution would work best in this case. Another solution if you can drill a hole in the sheet metal is a rivet nut like these from Pegasus Auto Racing shown at this link:
I thought of another idea; weld your captive nuts (or you could use bolts in this case) to some bar stock and welt the bar stock to the flooring. This would give you some additional structural rigidity and allow you to lay in deeper soundproofing.
