Capillary tube temp gauge
RonR
Folks,
What is the likely causes for a capillary tube temperature gauge to stop working, and is it repairable?
The is a1.5-inch long section where the outer "coil" is missing, but it use to work even with that is.
Thanks.
Ron
Michael Oritt
Ron--
They stop working when the ether leaks out, usually because of mishandling the tube, esp. where it connects to the bulb. They are easily repairable by professionals--Nisonger here on the east coast and some places out west. We just discussed this a few days ago so for more info use the search engine to find the string.
55modified
I just went through this. Unless you are sensitive about replacement parts, i would suggest buying a new gauge rather than rebuilding one.
dklawson
If you do decide on replacement instead of repair... remember you still own a British car. Don't throw the old gauge out... keep it to trade or sell it for parts.
Why? At Moss, new gauges cost $300-500, depending on model. The couple rebuilds I've had done were +/-$200; and the Moss replacements are slightly different than original. There might be some NOS gauges around, but the price would be dear.
steveg
If you're driving a BN1 or 2, the Moss replacement safety gauge matches yours - not true in the case of the 6 cyl cars.
D TR2/3/3A tr3 temp guage capillary tube thread size Triumph 3
K TR2/3/3A Temp gauge capillary tube routing? Triumph 11
B Temp gauge capillary tube Austin Healey 3
S Temp gauge capillary tube Austin Healey 8
mountainman TR 3 Temp Guage Capillary Tube Triumph 6
germanmichel Capillary tube of oil/temp.-gauge as single part ? Austin Healey 8
D Capillary Oil Tube Fastener Austin Healey 5
M Capillary Tube repair Spridgets 4
woolfman General MG Replacing capillary tube MG 10
T TR2/3/3A Capillary Tube Clips Triumph 4
martx-5 TR2/3/3A TR3 Capillary Tube Clamps Triumph 16
R Temperature capillary tube removal Austin Healey 10
M BN4 Capillary tube attaching Austin Healey 2
CharlieCarpenter What tool to use to disconnect capillary tube Austin Healey 6
T TR2/3/3A How do I remove temp gauge capillary end from thermostat housing on TR3A? Triumph 8
Tinkerman TR2/3/3A Attaching the temp capillary to the fuel line. 3A Triumph 13
beaulieu fixing a cut in half Temperature capillary gauge Restoration & Tools 13
Atrus 1/8” Capillary Tubing [Dizzy Advance] Spridgets 8
C Capillary pipe clip Austin Healey 2
tinman58 TR2/3/3A Vent tube Triumph 3
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
K TR2/3/3A The Amco chrome tube type grille ....... Triumph 9
P MGB Tube axle wear MG 3
AUSMHLY BJ8 Overdrive Accumulator Spring Tube Austin Healey 1
G Stator Tube Nut and Olive Austin Healey 9
Cutrog1 BJ8 Fuel Tube Installation Austin Healey 10
P Classic Tube Pre-Bent Brake Lines Austin Healey 5
71TR6 TR2/3/3A TR3A Breather Tube Attachment Triumph 6
C TR2/3/3A stator tube Triumph 6
B TR2/3/3A Control Head/Stator tube orientation Triumph 8
M TR2/3/3A Removing Wires From Stator Tube Triumph 7
K TR2/3/3A Making your own steering wheel stator tube? Triumph 16
aero3113 For Sale Big Healey Tube Shock Conversion Austin Healey Classifieds 2
T TR2/3/3A Can someone confirm size and thread count on fuel line tube nuts [brass fittings]? Triumph 16
Jim_Gruber Pages from Porter Spridget Restoration Manual on Seat Recovering, You Tube Videos Spridgets 4
D TR2/3/3A stator tube will not go down Triumph 0
AUSMHLY Tube vs Tubeless discussion :] Austin Healey 28
F TR2/3/3A Tie member[front apron support tube] Triumph 11
S Wanted stator tube Austin Healey Classifieds 0
S stator tube nut Austin Healey 7
D Best little tube bender Restoration & Tools 8
K TR2/3/3A The rear axle "tube" seal replacement. Triumph 6
D You Tube made me do it. I bought a Milwaukee dry cut saw. Restoration & Tools 6
K For Sale Curved tube intake manifold...2" Triumph Classifieds 2
M Questions about stator tube and trafficator fixation Austin Healey 31
X BE jacking tube access holes and top bows. Spridgets 1
Sarastro General TR How is the axle tube attached to the diff housing? Triumph 16
D BT7 stator tube Austin Healey 39
