Nelson
Decent weather today prompted me to do the first oil change since getting back on the road. This is supposed to be a simple no-brainer job. Not in my case. Apparently when I installed my screw on oil filter I over tightened it and now I can't get it to budge. Originally I had the canister type and I switched to the screw on type when I rebuilt everything. First I had tried a rubber strap wrench but that didn't budge the filter. Then I used a big slip joint pliers and now I have a hole in the side of the unmoved filter. Unless I am the first person to over tighten the filter I hope someone has a suggestion to get the @#$% thing off the car. Someday I'd like to do a job that goes easier than anticipated.
Hi Guest!
