TR3driver
Great Pumpkin - R.I.P
Generally, it's best to start a new thread with a new question. There may be folks that are interested or have something to contribute; but didn't read this far because they looked at the start and decided they weren't interested.hermanmaire said:Since I am posting, I have another question. When I turn the ignition key off, the engine stops but then it continues to sputter. It will continue to do this unless I block the carburetor intakes to kill the engine.
In addition to the possible causes Frank mentioned, just having the throttles open too far can aggravate the problem. My TR3A didn't like to idle below about 1200 rpm and would frequently run on if conditions were right (hot weather, high underhood temps, etc). The fuel we had in CA back then seemed to also aggravate the problem.
So, I learned to leave it in gear, with my foot firmly on the brake, and let the clutch out just after turning off the key. Takes a bit of practice to get the timing just right, but it will stop the engine from running on without hurting anything else. And if you time it just right, it's so smooth that no one (including you) will know if the engine would have run-on or not
