wkilleffer
I have been trying to change out the driveshaft and ujoints for my MGB for a bit of time now. Thanks to Tony and NAPA, I now have all the parts. The trouble is that I can't get the car up high enough with my autozone jack and jackstands. I can't get under the car at all, and can barely see the driveshaft. My arms aren't long enough to get to the bolts.
Part of the problem could be that I have a gravel driveway. It's pretty packed down, but there's still some sinking. The garage has a concrete floor, but it's sloped and I'm not sure I can get the car in there, even with someone to help me push it.
I'm not against the idea of buying a better jack and stands that would get the car up higher even though they look expensive. That could be what the Sears card is for though. But I don't want to do that if it's a bad idea. If someone out there has some ideas where I can use what I have, it would be great. But I'm willing to consider any ideas at this point. Any advice would be appreciated. Having the car on the road in time to drive it to work Monday would be a real plus.
Thank you,
Thank you,
