Brian_M
Helping a neighbor get his TR-3 back on the street - I got pulled in because I drive an MGB. Never worked on TRs before.
To date, I've put new carbs on, reset valves, new plugs, coil, set the timing (kind of) and did a tuneup. However, I can't get the idle below about 1,000 (idle screws are fully backed out) which says either vacuum leak or the timing is overadvanced.
So, my question: I understand it should be 4 BTDC static, no more than 32 degrees total. I've got an adjustable light - anyone know what advance I should see at idle, either with or without vacuum advance connected?
She's running at 4 BTDC dynamic at idle with vacuum right now. Figure if nothing else, I can just run up RPM until I get max advance and see where we are.
