Can this be fixed ??
Depending on the cost of a replacement block, stitching is an excellent solution. It's mature technology and used extensively to repair marine engines that cannot be (easily) removed from ships, so if you'd like to re-use your block, I'd make enquiries as previously suggested and see how much it would cost.
There are two ways to weld: Firstly by taking the block to a cast iron welding specialist who will, as Michel says, heat the whole thing in an enormous oven to a dull cherry red and then gas weld the cracks, but it take days and costs a fortune. Alternatively frost damage cracks can sometimes be arc welded successfully with nickel rods, I've had repairs done to TR heads where the thermostat mounts and to the block where the recess for the head studs has cracked. It's not expensive and if the cast iron is good quality, it's fine. But is can trash the block if you're unlucky. Some braze cracks, but I've only seen unsuccessful attempts, one to a BMW 328/80 engine where over tightening head had lifted and cracked the block surface.
I should add that the full process of gas welding a heated block usually causes some distortion and all surfaces need checking to make sure they're still true. The camshaft and main bearing housings may also require line boring.
Im going to hunt for a suitable replacement block of the correct era to remain true to the cars origin . I will keep the engine tag from the junk block to show any prospective future owners that it was all matching before the rebuild .
Does anyone have a line on a suitable replacement block ?
PM me pls .
Um.....do those head bolts go into the water jacket?
Pin it (K&W), sleeve the threaded holes, stop drill the crack at upper right.
I did. That's why I didn't offer one of my two spare blocks
Well ya all know this is kinda like what the old folks use to say:
"You can lead a horse to water but you can't make him Drink " :glee:
OH !! they had another one too:
" Hard times make a Monkey eat red pepper" But I don't think it will work here either.
The engine shop I took it to (which has a very good reputation) told me it will cost 2500 to 3000$ to make the block useable again using a combination of welding and lock n stich to fix the cracks . Then rebore , line bore etc etc ready for rebuild . Also there would be no guarantees on how long the repairs would last .
Its just not cost effective in my mind .
