Nunyas
[ QUOTE ]
[ QUOTE ]
Just don't put it back in. This is my choice. for the short term anyway.
[/ QUOTE ]
That would be my first choice but the studs coming from the manifold are not threaded until the last inch or so...so without the spacer I run out of thread to seal the carb to the manifold.
[/ QUOTE ]
Not only that but the shape of the carb would not allow you to seat the carb against the intake manifold without changing the mount studs. At least two of the mounting studs will impact against the carb body preventing you from getting it all the way to the manifold.
Without a doubt, the easiest work around without getting the proper replacement part is to fabricate a spacer of the same thickness as the heater element.
[ QUOTE ]
[/ QUOTE ]
[/ QUOTE ]
