Ohiobugeye
Can a Bugeye ignition switch be replaced with a universal ignition switch ? If so how would the wires be attached ?
I would think that the hydraulic line fittings are the same and the bores are different.Clutch hydraulic problems . When I got the car running well i went to bleed the hydraulic system starting with the clutch. The tube some how developed a pin size hole and when the clutch was pumped it sprayed hydraulic fluid all over the engine bay. When I converted the front brakes over to disk I changed the master cylinder over to a 3/4 inch but evidently I left the old 948 slave valve in place . I ordered a new tube assembly from Moss ordering the 1275 package and when I installed it the fitting to the slave valve the fitting threaded but seemed tight and when I pumped the clutch it once again sprayed fluid all over the bottom of the engine and floor . I stripped the threads to the slave valve. I rooted thru my parts and I found a new and 2 used slave valves after I ordered a new 948 slave valve. My question is does anyone know the thread size and type of the 1275 master cylinder and the 948 and 1275 slave valve. the tube size is 3/16 on both . I truthfully had no idea that the 2 slave valves were different until I noticed different part numbers in the Moss catalog.
I wonder if the aftermarket parts have metric threads.I would think that the hydraulic line fittings are the same and the bores are different.
I wouldn't be surprised. I spent an entire summer chasing a clutch line leak (1500) only to find the tolerances were so bad at the Master and Slave that it wouldn't seat at the bottom. I finally took my old ends and found a line to fit (plastic on the 1500) - Ohio Bugeye you might have an issue with it seating as well. The Threads I think are standard - same as brake lines - pretty sure it is 3/8 24.I wonder if the aftermarket parts have metric threads.
I don't think it is on purpose - it is parts sent out to jobbers - low bids *cough* chinesium *cough* - can't think what part I have under the hood - possibly the solenoid that has a metric screw - just because. My biggest issue with new parts though is not metric it is sloppy tolerances.Surely they wouldn't change to metric threads knowing the other end is not. Ok, I assumed too much intelligence, didn't I.
