Hi Patrick/Steve,
Patrick,
First, 1/10" = 0.1" or 2.54 mm. I mis-spoke about the needle step and really ment the to say the line on the needle that you set to the bottom of the piston.
Steve,
I agree that setting the needle a 1/10" deeper into the piston would be equivalent to dropping the valve 1/10" to increase richness. However, that would be at run and not at idle where the butterfly is closed and the HD idle is supposed to be solely dependent on the setting of the slow idle needle valve adjustment. Maybe there is a reason this works that I don't understand and the reason I qualified the level of my knowledge and what this action would do.
Ray(64BJ8P1)
It would be at idle, too. All the fuel supply comes through the main jet. The slow running valve admits a small flow of air/fuel mixture that bypasses the closed butterfly.
