bugedd
I was thinking that while I have my motor out while I rebuild my trans, I may put a lumpy cam in the 1275. I had a guy tell me that even the stock cams can flatten out over time, reducing lift/duration, so now might be the time to cam it.
What I would like is something mild/moderate, streetable, but noticably lumpy and peppy. Any suggestions on what to get? The car is a driver, so low to mid range power band is what I am after. And do all 1275's use the same cams, or is there some variation? Carburation is a Weber DGV if that has any influence, header is on the car as well.
Thanks
Thanks
