Hi,
I am in the process of timing the cam in my TR6 engine and I am having trouble determining the point at which the cam starts to open and the point at which it is closed.
I am using a dial gauge on the exhaust and intake lifters to do the measurements. The cam I am using is a stock regrind of a post 72 cam.
I find that it is very difficult to get an approximate start of the lift (or end of close) as it starts off very gradually and then shoots up quickly.
From my research on the net, some videos say that to determine the position at which the cam starts to open, you use the point at which the lifter has gone up 50 thou. However some videos don't mention this at all. I Also find the same for determining the duration of the cam.
So, my question is, which way is correct on a Triumph, from 0.050 lift (easy to measure), or the point at which it just starts to lift (hard to measure)?
Thanks
Thanks
