Any idea what temperature neoprene starts to melt at? Or how compatible it is with brake fluid?
I should have stated that the system was completely rebuilt and is using DOT5 in a TR6, when Girling updated there seals from natural rubber they went to Neoprene so the use of DOT3 could be used and would not break down the natural rubber seals, if using the old seals with DOT3, DOT4, or DOT5.1 they will deteriorate hence the use of Castrol/Girling LMA, a vegetable-based fluid. Silicone DOT5 is compatible with Neoprene.
Chemical Composition: Polydimethylsiloxane Fluid (PDMS)
Use: DOT 5 Silicone Brake Fluid is a silicone-based (Polydimethysiloxane CAS# 63148-62-9) fluid that is formulated specifically for used in hydraulic brake systems to provide corrosioin protection and lubrication. DOT 5 Silicone Brake Fluid is recognizable by its bluish-purplish color. In comparison to DOT 3 & DOT 4 Brake Fluids, DOT 5 provides higher thermal stability and higher dry and wet boiling points. In addition, being silicone-based, DOT 5 is hydrophobic and will not absorb water.
DOT 5 has a service temperature range of -55°C to 55°C. Its dry boiling point (no water present) is 260°C and its wet boiling point (contains 3% water) is 180°C Due to these properties, DOT 5 Silicone Brake Fluid is widely used by the military. It meets Mil-PRF-46176 & Mil-PRF-46176B. DOT 5 Brake Fluid also meets SAE J 1705 Society of Engineers.
DOT 5 Silicone Brake Fluid is compatible with a wide range of brake materials including <span style="font-weight: bold"><span style="color: #3333FF">SBR, EP, Neoprene and Natural Ruber</span></span>.
Meets the requirements of the following specifications:
•Mil PRF-46176
•Mil PRF-46176B
•SAE J 1705 Society of Engineers
•Meets NSN 9150-01-0728379
Features:
•Silicone-based fluid
•Hydrophobic…will not absorb water
•Appearance: Bluish-purplish fluid
•Wide service temperature range
•High Dry Boiling Point
•High Wet Boiling Point
•Long service life
•Compatible with a wide range of brake system materials
•Will not damage paint
Availability: 5 & 55-gallon containers
View Product Specs
View MSDS
View Mil-PRF-46176B
View Guide for Military Specifications
View Use Only Silicone Brake Fluid from U.S. Army
