Susan Lybolt
Member
I by passed the heater. Should the valve on the block be closed or open?
Couple of points:
- If you close the valve, you won't have the 'last ditch' option of using the heater as an auxiliary radiator in case you start to overheat, say, pulling the grade up the Panamint Mountains out of Death Valley on a 115degF day (don't try this at home)
- It's a good idea to occasionally turn the valve on/off, as they tend to get stuck if not exercised, and it's easy to break the little brass handle off the valve (of course, I would NEVER do such a thing)
The judicious use of a small hammer prevents that.My heater is still intact, but I leave the valve on the block closed.
Well John:
Under those conditions the car owner and the little brass handle on the valve have been known to part the ways.
Probably not, but I suspect people in Michigan get caught in traffic jams on a warm summer day, where an extra 2-3degF in cooling can make the difference between boiling over and not.I don't think someone in Michigan needs to worry about "pulling the grade up the Panamint Mountains out of Death Valley on a 115degF day".
Those little brass handles are available now.My heater is still intact, but I leave the valve on the block closed.
Well John:
I have a 57 100-6 that has a very hot cabin and want to turn off this heater valve. Where is it located and what tool will I need? Thanks.
It's near (between?) the #5 and #6 cylinders, on the starboard side of the engine. Theoretically, it can be turned by hand but if it hasn't been 'exercised' occasionally it will likely be frozen and the handle will break off when you try to turn it. All you can do is soak with a good penetrant, try to move it by hand then try with leverage, in which case the handle is likely to break. You can try to disassemble the valve in place and gently tap the movable part out, but I've never done this so can't speak to your chances.
Think there might be a valve on the heater itself, but don't recall for sure. If so, and you can't budge the valve on the engine you might try this one instead.
