bumperettes position BT7
pasraf
Hey All
I'm debumpering my BT7 ,front 2 Lucas lamps , rear Bugeye bumperettes.
Question is does the small side of the bumperette , has to point up ?
In de pictures on the web , I see different mountings
Regards Raf
dougie
Hey All
Regards Raf
Here's how they looked on the Works cars.
P
pasraf
Hey Dougie
Thanks for a fast response
I've put them the right way.....
But I've made some new supports (braquets) to get them closer to the body....
Need to put them a little down because boot (lid) was in the way
But the view is better ,close to the body.....
regards Raf
dougie
I agree, I've always thought the stuck out too far. How about a picture when you're done.
Best
P
pasraf
Dougie
Will do so (I'll make some pictures)
But first I want to finish it
I've made new supports for the front lucas lights and made some towingsupports aswell
Took of the Wwheels to sandblast and paint them in black (sandblasting is done but painting willbe done @the end of january)
Made some new supports for the bumperettes.
I think the Healey is more "attractive" without bumpers , but thats my own opinion (without starting a debate,yes or no)
The Healey btw is OEW
regards Raf
dougie
Dougie
Where and when was that photo taken?
I'd like to say in my driveway last weekend, but I can't remenber where it was taken.
P
pasraf
Hey Andrea
Making new brackets for the rear aswell
To get them close to the body and in the correct possition ,needs a lot of tray and adjust
Thanks for those pictures
regards
Raf
R Bugeye rear bumperettes Spridgets 8
HealeyPassion Work rally bumperettes project paper Austin Healey 10
eschneider stainless bugeye bumperettes? Spridgets 1
B Bumperettes Spridgets 2
M New to List - Bumperettes & Color Combos Austin Healey 33
RobSelina Using Bugeye rear bumperettes on an RB car. Spridgets 0
G Bumperettes MG 5
L 1994 XJ12 Throttle Position Sensor unavailable, alternatives ? Jaguar 1
P Pedal Position Adjustment Austin Healey 2
A TR2/3/3A Seat position Triumph 2
Healey Nut Seat Base Frame Position Austin Healey 4
Jeepster Clutch Pedal Position Austin Healey 4
chicken Inner Door Seal Trim Position Austin Healey 6
B Roof vent position on BN7 hardtop. Austin Healey 15
G Valve adjustment and easiest way set cam position Austin Healey 15
steveg TR6 TDC - Position of rotor and wires Triumph 4
L Seat position for a BN1 Austin Healey 0
Upland 3 position headlight switch is now 2 Spridgets 1
J TR2/3/3A Front apron position Triumph 9
D AH 300O MK1 Choke Knob Position Austin Healey 5
G BJ7 Window channel position Austin Healey 1
maxwedge5281 steering tight in center position of steering wheel Austin Healey 2
K TR2/3/3A TR4 motor with overdrive in a TR3 slave cylinder mounting position? Triumph 2
D TR2/3/3A Dipper switch position Triumph 13
W Cam gear position BJ8 Austin Healey 11
S TR2/3/3A how to position pieces when painting Triumph 7
J MGB 1977 MGB starter activates when key on the "on" position. MG 6
E TR4/4A TR4 Radiator position with Macy's garage Fan Triumph 6
S TR6 Position of the buffer wedges under the hood [ bonnet] on a 74 TR6 Triumph 2
S TR4/4A Ignition switch key position Triumph 2
J TR4/4A Horn clip position. Triumph 6
K TR2/3/3A Correct position for flasher bracket? Triumph 7
N TR4/4A no spark in start position Triumph 8
gbtr6 TR6 Help! Starter runs with ignition in on position Triumph 18
M TR4/4A Position of wiring loom inside the trunk/boot area. ? Triumph 3
E TR4/4A TR4 Throttle shaft position Triumph 1
R TR2/3/3A Position of LTD fastener on new top Triumph 5
M Accelerator Pedal Position Austin Healey 4
J TR4/4A 175 CD needle position? Triumph 5
TRclassic3 TR2/3/3A SU Upper jet bearing position Triumph 5
2billydavies TR2/3/3A dumb question of the day: engine fan for TR3a position Triumph 11
A TR2/3/3A TR-3A steering wheel position [measurment needed] Triumph 3
Gliderman8 TR6 Starter energizes when in RUN Position...... Triumph 17
vette Seat floor position Austin Healey 10
B Spin on oil filter position Austin Healey 1
P Interior door opening handle position Austin Healey 11
Tinkerman Wheel Knockoff position Triumph 7
T Spitfire Grease slinger position on a Spit 1500 axle Triumph 7
Xte Needle BJ8 position in HD8 carb ? Austin Healey 4
S XKE Accelerator Ppedal Position Jaguar 2
