Frank Canale
This is the front bumper brackets that bolt to the frame. The PO used a torch to remove the weld nuts from the bracket.
I am not a machinist, but I do have a small Atlas lathe that I played with at the shop I started in when I was in high school. A local machine shop was kind enough to give me a short piece of 3/4" hex stock to make the 3/8-24 weld nuts. These nuts are an odd size so I decided to give it a try and make a couple. This was an opportunity to try and do something that I don't normally do.
There was enough of the original hole that I could leave that part, weld in the repair and use a rotary burr to finish grinding the hole to the correct diameter for the weld nut.
Bumper frame bracket with the weld nut in place. I am going to wait to weld the nut in until I get a bumper and am able to bolt everything in place. It will be easier to make adjustments before the nut is welded in and I won't have to make the nuts over.
Both brackets have been repaired. They both seem the same but there might be a minor difference where the bumper bracket attaches so there might be some tweaking to be done once they are installed. This is why my restoration will take longer than it should, silly details like this, but I had a lot of fun making the nuts for this repair. I guess that is what its all about. Very cold and ice and snow headed my way so progress will be limited. Stay warm, Frank
