Bump Stop Box
John Morralee
Please,what is the correct distance between the bump stop box and the rubber mount on the axle ,which the box contacts, for an unloaded '63 BJ7. thank you in advance . John M.
John,
I have a 64 BJ8 phase I which should be the same as your BJ7. By unloaded do you mean the the wheels off the ground supported by the suspension? Have a good day!
John
John,
I was able to get a distance of 3 1/16" on the passanger side. The driver side is blocked by the exhause pipes. I don't know if this is correct but it is what I have. Hope this helps and have a good day!
John
