swift6
My brother has a custom VW that is nearing completion. It has been chopped 4 inches, has suicide doors, rear fenders are 4 inches wider than stock and fronts are 3 inches wider than stock. The engine is a Bernie Bergmann crate unit, 2110cc and makes 128 hp, 114 lb-ft at the crank and puts the power to the ground through a Freeway Flyer trans axle (fourth gear is an overdrive). The wheels and tires will bolt right onto a Porsche Boxster and it has four wheel disc brakes. Most of whats left to do on it is finish the wiring, interior and get the custom glass made.
We spent the weekend at a Good Guys Hot Rod show. It drew a LOT of attention. The most common misconception was that we had stretched the car. Here are some pics...
