Well, those of you that had faith I'd not screw up the front suspension rebuild have been sorely disappointed (you'll get over it I'm sure). I finished the rebuild, made sure everything was tight and then took her for a drive. Once she settled in she was rubbing her tires when I made any sort of turn.
Some background - this is the car that had the bent spring pan.
1) Should the car settle after 10-20 feet of driving?
2) Ideas as to why she was lower on the driver side than the passenger side despite using the same springs and bushings all the way around?
3) I installed the shorter 8.75 tall by 3 inch (interior diameter) wide front springs from this thread;
Old thread on springs
which suggest I need to go back to regular height.
4) The original springs are slightly uneven in height as you can see here and look slightly bent. Am I correct in that due to the height mismatch and bend that they are scrap?
