Bugeye transmission
fordtrucks4ever
Yes. Make sure you install the 1275 too. Its the best way to keep it looking totally stock and big difference on performance.
Billm
Yes- the tranny will fit fine either way, just check before you put the assembly in the car that the clutch yoke moves properly in the tranny hole and appears to contact the pressure plate before the the yoke hits the back of the hole.
BillM
Jim_Gruber
Don't you need to change the back plate on the engine? Or maybe I'm incorrect but I thought there was a difference in backplates between a Rib Case and a Smoothcase. Someone who's done this please educate us.
Billm
Actually you don't need to change it, the thickness change is only around 1/8" and the spline/clutch takes care of any problems there.
The only combination problems are if you put a smoothcase tranny up to a 1098 engine the pressure plate fouls the tranny bellhousing and needs to be cleared (this is only because the 1098 pressure plate is HUGE).
BillM
M What is the proper oil for Bugeye engne and transmission Spridgets 6
R Bugeye transmission sticks in neutral Spridgets 5
TulsaFred 1275 Ribcase transmission in Bugeye - Which slave and pipe? Spridgets 23
I Bugeye transmission options? Spridgets 11
R Bugeye ignition switch Spridgets 2
T Music Video with a Bugeye, plus a hill climb video Spridgets 1
D For Sale 1958 A-H Bugeye Sprite Austin Healey Classifieds 3
Todd78d Bugeye carpet Spridgets 7
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Todd78d Bugeye choke linkage Spridgets 5
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
R Wanted Bugeye ignition switch Spridgets Classified 2
CARSINC 1965 Sprite Bugeye Spridgets 5
drooartz The great Gordon Murray has a Bugeye! Spridgets 0
W Bugeye Tudor Wash Bottle Decal Spridgets 0
R Bugeye drum brakes Spridgets 7
SNClocks Bugeye Alignment Spridgets 4
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
J Finally getting (re) started on the Bugeye Spridgets 27
drooartz Restoring Penny the Bugeye Spridgets 22
drooartz Bugeye jack points to remove rear axle Spridgets 18
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
SNClocks Bugeye axle limit straps Spridgets 5
R Wanted BUGEYE SHIFT LEVER Spridgets Classified 6
R Bugeye Starter Switch Spridgets 7
Lin Bugeye Axle Hub & Bearings Austin Healey 1
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
Lou E Finally a Bugeye of my very own Spridgets 41
5 Sold My 1960 Bugeye Spridgets 10
SNClocks Goings on with our new Bugeye Spridgets 1
F 59 bugeye spring bushing bolt Spridgets 8
Rut 3 point belts in a Bugeye? Spridgets 9
JPSmit gluing a panel on to a bugeye Restoration & Tools 2
I Bugeye oil leak help Spridgets 4
I Bugeye lack of power Spridgets 1
I Bugeye charging issues Spridgets 8
I Bugeye smoking Spridgets 9
I Bugeye valve rebuild suggestions Spridgets 8
jfarris Immaculate 1958 Bugeye Spotted 4
drooartz Leno's Bugeye Spridgets 12
R BUGEYE SOFT TOP FIT Spridgets 2
R Bugeye splined wheels Spridgets 0
T Wanted Bugeye Sprite RHD tonneau cover. Austin Healey Classifieds 0
Jim_Gruber Bugeye Seat Pans needed Spridgets 1
B Fluctuating Fuel Gauge 1960 Bugeye Spridgets 4
