Bugeye Tire Size and Wide White Walls
John Moore
I really want to sell the Anson sprite wheels that came on my Bugeye. Right now I have a bid on a set of original steel bugeye wheels on ebay. (Let me know if anyone else is planning on bidding against me!)
But what size tires do most of you guys run on your Bugeye? Also, I'm thinking I would like to get wide white walls! LOL! Other than Coker, does anyone else know of a place to get big white walls in a size that would fit a bugeye?
John Moore
John Moore
Here's another newbie question.... do the original steel wheels require tubes?
GB1
John:
If I remember correctly they do not require tubes. Close to original tire size would be 145x13.
Early rims were riveted together, so when I did run them, I had them tack welded.
Hope this helps,
Pat
What are Ansen Sprite wheels?
The original tires were closer to 78 ratio.
John Moore
John Moore
They are 60/70's looking slotted mags.
Oh... OK,
BTW, my preferred tire size is 165/70.
Since we're on the subject of white wall tires.....I am trying to find them for my Mini....I saw an original ad for the traveller that had wwt's and original hubcaps....any sources, please let me know. Coker doesn't carry them.... /bcforum/images/%%GRAEMLIN_URL%%/frown.gif
mrsprite
Hey John,
I have a set of Bugeye wheels that I got from 'Billm' several months ago. They are nice, but need painting (not rusty, etc.). LMK if the ones on eBay don't pan out.
Mike
John Moore
John Moore
Thanks Mike,
But I ended up "winning" the BE wheels on Ebay. If something doesn't work out, I'll let you know.
jlaird
Why there is my luggage rack. Had not realised that.
Mine is packed in my closet. Have not made up my mind wether to use it or not. But it sure is preaty.
A bugeye tire size Spridgets 5
longbridgehealey Bugeye tire size Spridgets 2
I Bugeye tire size Spridgets 3
B Tire size for a bugeye Spridgets 13
H Can a 175x13 tire be fitted on Bugeye Spridgets 6
5 Original Bugeye Rim and Tire Spridgets 6
AN5Sprite Bugeye Tire Pump? Spridgets 7
I Bugeye tire pump Spridgets 1
I Source for Bugeye tire pump parts? Spridgets 14
Trevor Jessie Gundy Bugeye tire question Spridgets 6
I Tire selection help for Bugeye Spridgets 12
Chatis Tire's [Tyre's] for a Bugeye Sprite Austin Healey 2
R Bugeye ignition switch Spridgets 2
T Music Video with a Bugeye, plus a hill climb video Spridgets 1
D For Sale 1958 A-H Bugeye Sprite Austin Healey Classifieds 3
Todd78d Bugeye carpet Spridgets 7
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Todd78d Bugeye choke linkage Spridgets 5
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
R Wanted Bugeye ignition switch Spridgets Classified 2
CARSINC 1965 Sprite Bugeye Spridgets 5
drooartz The great Gordon Murray has a Bugeye! Spridgets 0
W Bugeye Tudor Wash Bottle Decal Spridgets 0
R Bugeye drum brakes Spridgets 7
SNClocks Bugeye Alignment Spridgets 4
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
J Finally getting (re) started on the Bugeye Spridgets 27
drooartz Restoring Penny the Bugeye Spridgets 22
drooartz Bugeye jack points to remove rear axle Spridgets 18
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
SNClocks Bugeye axle limit straps Spridgets 5
R Wanted BUGEYE SHIFT LEVER Spridgets Classified 6
R Bugeye Starter Switch Spridgets 7
Lin Bugeye Axle Hub & Bearings Austin Healey 1
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
Lou E Finally a Bugeye of my very own Spridgets 41
5 Sold My 1960 Bugeye Spridgets 10
SNClocks Goings on with our new Bugeye Spridgets 1
F 59 bugeye spring bushing bolt Spridgets 8
Rut 3 point belts in a Bugeye? Spridgets 9
JPSmit gluing a panel on to a bugeye Restoration & Tools 2
I Bugeye oil leak help Spridgets 4
I Bugeye lack of power Spridgets 1
I Bugeye charging issues Spridgets 8
I Bugeye smoking Spridgets 9
