Check grounds first
I've had brake light switches go bad, has yours been replaced or repaired?
If you have the old original type you can take it apart and repair it - it will be much better than any non-NOS replacement.
Easy enough to check, put a meter on and see if it opens / closes the circuit when the brakes are pressed.
