Bugeye pull starter
Rut
Well, we’ve made some progress on my buddy’s Bugeye, but the replacement pull starter switch sticks with a passion. Everything works as it should, but it feels like it’s welding itself together when you pull it. I either pull the battery cable or knock the starter switch back down to get it to stop...what gives?
Thanks, Rut
Crap Asian quality?????:rolleyes2: Maybe use it to actuate a relay oooorrrr maybe there is too much of a load from a starter with problems.
Kurt
Kurt
Crap Asian quality is my vote. Good GR starter that actually fits!
Rut
Go for a relay.
It is a stock starter or a GR unit. GR unit has a built in Solenoid/relay so there should not be a load on the pull switch.
If stock Lucas then the pull switch is at full motor draw. Could be a problem with the starter causing the overcurrent.
I run an old Ford solenoid with a stock starter.
Joe,
The pull starter is a repro and the GR starter has the solenoid wire jumped to the + terminal on the starter. IIRC it’s set up the same way the original was.
Thanks, Rut
Rut
You lost me, senior moment here.
IIRC ??
Thanks, as I said senior momment
Simple solution then, Rut. GR starter just needs a dedicated big cable to the starter solenoid and the switch only needs to run the solenoid!
Kurt
Kurt
Thanks, it finally dawned on me and I’ll correct both cars!
Thanks, Rut
