Rut
Guys,
The welding on my Bugeye is nearly complete and I finally turned my attention to the engine and transmission. The 1275 has always been a leaker when running with some success using a variety of crankcase venting. I finally separated the engine and transmission (smooth case) and the inside of the bell housing had no oil stains! I always assumed the scroll seal was the culprit, but the leak has got to be elsewhere. I'll pull the clutch, flywheel, and rear plate and hopefully find the answer...any suggestions?
Rut
Rut
Hi Guest!
