Hi all!
It's been awhile since I last posted or put any significant time working on my Bugeye. Since last I posted, I had put in the hydraulic fluid (Castrol LMA) and bled the clutch and brake lines.
At about that time vacation and other time drains kept me away from the car. When I went back I discovered my "rebuilt" master cylinder was leaking at the joint where the top joins the body of the MC. (Item #7 on the picture below.)
The MC was rebuilt by a vendor that seems to not get rave reviews here. Also, the MC sat on a shelf for about a year before I installed it.
The leak trashed the paint on the pedal box and pedals, but luckily not the car itself. So last night I removed all fluid from the system and pulled the MC and pedal box.
Also, as point of reference for one of my questions, this car has front disc brakes.
Now here are my questions:
First, is the leak at the top plate to the MC body a typical leak point and will a new gasket be the simple fix or could this be an ongoing issue unless the mating surface are cleaned up. (I haven't removed the plate yet to assess the mating surfaces.) Is this a dry fit seal or should some form of sealent be used?
Second question concerns the conversion to disc brakes. When I had the MC rebuilt, it was before I found this website and all the knowledgeable, helpful people who post here. I questioned the rebuilder about re-sleeving the MC to 3/4" for the disc conversion but was assured by him it was not necessary and it was left at 7/8". Subsequent reading here and elsewhere, points me to a different conclusion. Should I send this MC off and have it re-sleeved at this point?
I am also currently using the stock BE rear brake set up. If I am going to go ahead and sink more money in the MC, should I go ahead and find donor parts from a later car and change over the rears? I have read differing opinions on whether this is necessary, but if I am going to make this right I would rather do it now while I have the MC out.
I know the disc conversion has been discussed a lot on this board previously, but I would like to hear from others on how well the different combinations work in actual application.
Thanks in advance!
Thanks in advance!
Hi Guest!
