I have a number of questions concerning ligthing/electricity.
1) When I turn on the turn indicator, the green dash light does not come on. I know the problem is grounding, because I ran a wire from the outside of the bulb sockets to a screw holding one of the dash brackets and it did light up. The plastic insert going through the dash does not help things. How do you normally ground this light?
2) The ignition and high beam indicator lights appear to be missing the small colored piece of plastic or glass. What color were each of these originally? What could I use to correct this?
3) The wipers have two problems. When I pull the swich, they only come on half the time. Would the problem be the switch or motor, and how can you tell? The wipers normally start out slow, only complete four cycles in one minute and then goes faster the more I turn them on or off. This can't be normal- what is?
4)The ignition light stays on even without the key in. What could be causing this?
Help on any of these questions would greatly be appreciated.
Kevin
Kevin
Hi Guest!
