I am running the original mechanical stock fuel pump and what I think are original gas lines. The steel line runs from the gas tank and stops at the front right corner. A rubber gas line from the right front corner then heads to the left side of the car where it connects to a steel spiraling gas line that drops down on the left side. Another member warned me that I should reconsider the rubber hose connection because it is below the level of the line at the gas tank. He mentioned that this is a potential fire hazard since if rubber line fails the gas tank would be siphoned out quickly. So I have two questions; 1) Do I have the gas line routed/hooked up correctly? 2) If it is correct, do I have a reason to worry about this, and what could I do to make this safer? Don't know if the pics help, but here is a shot facing toward the back of the car on the passenger side.
