Bugeye fuses
rossco
My book tells me there are two 35 amp fuses. I've always heard one 35, one 50. What say you?
Problem. All lights working until I push brake pedal. Then RH tail light goes off.
RickF
Two 35's. You need to crawl into the boot and fix the grounds for the lamps.
vping
Bronze
I have 2 - 35's in mine. The lights ground to the harness.
vping
Bronze
R
rossco
No ground wires in the rear harness. I'll make my own. Where do I attach them to the light bulb holder?
vping
Bronze
Each holder should have a black and red pigtail.
Jim_Gruber
Replace one of those bolts fir the Bumperette stiffener with a nice shiny Bolt and lockwasher and nut after you run a tap through the captive Nut, I think it has a captive nut. Add a closed loop lug on the end of the ground wire and place over that shiny bolt you fed up from underneath the car, Add the other two ground lugs that have been soldered, heat shrink tape to neaten up the connection and when all 3 wires are on each side add a lockwasher and another nut on top. You will have no more issued with a bad ground back there. Again there are no ground wires in the rear harness. Those bulb all ground to the body. Yes I could have run one continuous ground wire but 3 separate wires made trouble shooting and isolation simpler. Dont foget the ground to the Plate Lamp.
Now one trick I added was a 1157 dual filament lower beehive lamp in the back, same base as the front turn signals. I ran a jumper wire from the brake lamps down to the low beam side of the new beehive lamp. Step on the brakes and it also lights up the low intensity side of the beehive lamp. Turn Signal stays wired to the high intensity side. All of my rear bulbs are now LED, I added the 72 LED Display for main Brake Lamps and 1157 Red / Red dual filament LED's in the Beehive lamps. UP front I used a White / Amber LED for the front Turn signals. PArking lights White / Turn Signals Amber. Works slick.
R
rossco
Jim. You always go the extra mile. I'll take some time to digest this and see if I can incorporate your ideas. Your car must be special. Thanks for taking your time to get back on this. Ross
Joe Schlosser
Remember that US fuses have a different rating then UK ones. They are not interchangeable.
vping
Bronze
Nice. I had to Google it after reading that there was a difference.
R
rossco
Went right to the Bugeye fuse block. 2 35 amp fuses;1 Lucas, 1 Buss. Changed out the Buss for a Lucas. Thank you Joe.
BobHaskell
The 6 cylinder Healeys have a 35 and 50 amp fuse. The only thing on the 50 amp fuse is the horns.
longbridgehealey Bugeye fuses Spridgets 5
R Bugeye ignition switch Spridgets 2
T Music Video with a Bugeye, plus a hill climb video Spridgets 1
D For Sale 1958 Bugeye Sprite Austin Healey Classifieds 3
Todd78d Bugeye carpet Spridgets 7
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Todd78d Bugeye choke linkage Spridgets 5
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
R Wanted Bugeye ignition switch Spridgets Classified 2
CARSINC 1965 Sprite Bugeye Spridgets 5
drooartz The great Gordon Murray has a Bugeye! Spridgets 0
W Bugeye Tudor Wash Bottle Decal Spridgets 0
R Bugeye drum brakes Spridgets 7
SNClocks Bugeye Alignment Spridgets 4
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
J Finally getting (re) started on the Bugeye Spridgets 27
drooartz Restoring Penny the Bugeye Spridgets 22
drooartz Bugeye jack points to remove rear axle Spridgets 18
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
SNClocks Bugeye axle limit straps Spridgets 5
R Wanted BUGEYE SHIFT LEVER Spridgets Classified 6
R Bugeye Starter Switch Spridgets 7
Lin Bugeye Axle Hub & Bearings Austin Healey 1
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
Lou E Finally a Bugeye of my very own Spridgets 41
5 Sold My 1960 Bugeye Spridgets 10
SNClocks Goings on with our new Bugeye Spridgets 1
F 59 bugeye spring bushing bolt Spridgets 8
Rut 3 point belts in a Bugeye? Spridgets 9
JPSmit gluing a panel on to a bugeye Restoration & Tools 2
I Bugeye oil leak help Spridgets 4
I Bugeye lack of power Spridgets 1
I Bugeye charging issues Spridgets 8
I Bugeye smoking Spridgets 9
I Bugeye valve rebuild suggestions Spridgets 8
jfarris Immaculate 1958 Bugeye Spotted 4
drooartz Leno's Bugeye Spridgets 12
R BUGEYE SOFT TOP FIT Spridgets 2
R Bugeye splined wheels Spridgets 0
T Wanted Bugeye Sprite RHD tonneau cover. Austin Healey Classifieds 0
Jim_Gruber Bugeye Seat Pans needed Spridgets 1
B Fluctuating Fuel Gauge 1960 Bugeye Spridgets 4
Basil For you Bugeye/ Frogeye fans Spridgets 5
B Bugeye Electrical Diagram with additions Spridgets 6
R 59 Bugeye rib cage tranny hard shift into reverse Spridgets 0
