My 1960 Bugeye has an original type (Smith Motor Accessories Limited) fuel tank sending unit. The metal float has some small areas worn through. The inside of the unit shows one broken copper wire and a multimeter indicates no current flow. Is it possible to repair or re-build for a reasonable price? What are some good options and good sources for replacing the sending unit? Thanks
Hi Guest!
