Glen_B
I finished the welding and grinding on the new intake manifold and installed it Sunday night. With a mower can of gas on the garage floor and the fuel system bodged together externally (pump/pressure regulator), I got the motor to fire up and run for 2 minutes. Enough "proof of concept" to carry on with the next step of adding the return fuel line and installing the new pump/filter/pressure regulator in a more permanent fashion.
The Megasquirt worked well, and the injectors must have worked as planned as the motor ran strong and sounded great. Much tuning to follow.
Breifly, Rayjay turbocharger, two 44lb/hr Lucas injectors, MSD fuel pump, Ford 1.9 throttle body, Megasquirt v.1
Glen Byrns
Glen Byrns
