Bugeye Front Wheel Bearings?
paulsherman
Does anyone have any manufactures part numbers for Bugeye front wheel bearings and oil seals. I can see what the usual suspects show, but do remember that I once had some actual part numbers for these items and much cheaper.
Thank you
Paul
Thank you
Paul
Paul,
Original are R&M. I can get you original numbers, but not sure this brand is available anymore, though can be cross referenced. Also, any bearing house can find you a replacement by supplying ID, OD and thickness just as easily. I can tell you that these OEM style replacements are not cheaper though. Last time I looked into this, prices were minimum 4 or 5 times more expensive than the "usual suspect" kits, and you have to buy seals separately too.
