Gerard
Trevor Jessie said:Capitalization does not matter in the URL domain name, only in the portion following and (as Rick said) depending on the server/configuration.
geez louise, I was just pointing out that in the URL that was posted (with lower case "w") , that it returns an error, so best to copy and paste a link so the reader does not have to guess why it doesn't work. (commonly referred to as "user friendly")
As a side note, while the guy did very nice work on the car, the notch in the front frame rail is unnecessary. I have done this swap in Morris Minors at least 4 or 5 times without needing to do this. The only reason I can think of why he might have done this is to make room for the heater to that exits the rear of the cylinder head. The way to handle this is to thread and plug the rear tap and relocate it to the front side of cylinder head.
Also, sorting the clutch linkage can be done in a less complicated fashion and I actually convert them to hydraulic and avoid all that fabrication all together. I wish he would have included from which car he sourced the shift boot. That looks pretty nice. In the past, I made a custom gaiter when not using the original.
Hi Guest!
