Bugeye dash grab handle
TulsaFred
I'm working on my dashboard, and my grab handle is a little pitted. A couple of questions:
1. Are the repro grab handles any good?
2. How is the grab handle installed? On mine there is an old piece of plywood behind the dash acting as a backer to the grab handle. What does it look like originally?
thanks!
Fred
From memory... laminated plywood, double thick around the edges, making a pocket in the center. The corners are cut off at 45 degree angle as I recall. Only two holes for thru pegs.
Interesting enough, when a radio is fitted, most often the plywood piece needs to have a chunk cut out of it!
I am having mine re-chromed. Haven't gotten it back yet, but the cost was $65 or $75. Jim
Well, I guess my wood backer for the grab handle is original, since it is as described. It does have a chunk cut out of the corner for the radio, too!
It's delaminating, so maybe I'll try to re-glue it and reuse.
Jim, are you having your grab handle rechromed because you don't like the quality of the repros?
thanks
Fred
Well, I already had the grab bar, and figured that a good chrome job would probably be nicer than a repro. Don't know yet if I that will in fact turn out to be right or not. Probably won't make a whole lot of difference. It's not like I have a show car. Jim
