Bugeye bonnet prop rod
Rhodyspit75
Would someone please post a picture of the bonnet prop rod in the down position? I think I have figured out how the fixed end mounts but not where the other end parks. I’ve looked at vendor diagrams and haven’t had much luck. Thanks Ernie.
Ernie,
I found this picture on the internet posted by Moss...hope it helps.
Rut
Thanks Rut, the problem I’m having is the Moss site says you only need one bracket (400-665) your picture seems to show two. The AH Spares site says you need two but also shows the clip already mounted to a different bracket. Having said all that, another member on another site showed me a picture of the clip simply bolted to the flange on the radiator. I think that is what I’m going to do.
