chickentender
Member
I have a '60 BT7. the turn signal bulb on the passenger side burned out. the bulb on the dash doesnt light either when the right turn signal is turned on. i replaced the bulb with a good bulb from the drivers side and nothing. i checked fuses and they are good. the drivers side is fine and the dash light blinks when the drivers side turn signal is on. any ideas?
Hi Guest!
