Healey Nut
So I have started reassembly of the car. Take a look at the pic. Rear axle in the car, rear springs mounted, fibre plate on top of spring rebound rubber on top of axle. The square plate that the U bolts go through has a hole in the centre that the pin holding the spring stack together goes through.
It won’t fit through the hole as the nuts are to large to fit through. So do I remove the nuts, install plate with flat washer, and secure the plate to the spring or ? (Sorry, the pic is sideways.)
